Digital Twins in Manufacturing: The Missing Layer
Digital Twins: The Missing Layer
You’ve probably heard the term digital twins in manufacturing before. You may have asked yourself what the hype is about and how it differs from traditional CAD/CAM simulation software.
Put simply, a digital twin is the next evolution of machine and process simulation. The goal is to simulate machining operations in the digital world before a single chip is made.
Imagine a workflow where your CAM software automatically checks for collisions, inefficient strategies, missed material removal, and machine limitations before production begins. That is the purpose of a digital twin workflow
The Gap Between Planning and Production
In most shops, there is a disconnect between what is planned and what happens on the machine.
  • Engineers define design intent
  • Programmers leverage CAM systems to define toolpaths
  • But the real interaction between machines, materials, tooling, and workholding only comes to life when chips begin cutting
That’s where:
  • Costly collisions are discovered
  • Tool deflection shows up
  • Workholding limitations become obvious
  • Cycle times drift from estimates
  • Lack of clearance is found
  • Oversights show up in QA
This creates a reactive workflow.
Instead of knowing what will happen and adapting before the cycle starts, shops are constantly adjusting to what happens after the cycle is underway.
What a Digital Twins in Manufacturing Actually Is
A digital twin is not just a simulation.
It is a virtual representation of the real machining environment.
Not just geometry — but behavior.
A true digital twin models:
  • Machine kinematics
  • Fixture, machine, and tool geometry
  • Tool dynamics
  • Material interaction
  • Workholding
  • Process conditions
It allows manufacturers to validate, optimize, and understand the process before a single chip is made.
Why Digital Twins in Manufacturing Matter Now
The pressure on manufacturing has changed.
  • Parts are more complex
  • Materials are more demanding
  • Tolerances are tighter
  • Timelines are shorter
There is less room for trial and error.
And less tolerance for inefficiency.
Every iteration on the machine costs time. Every mistake introduces risk.
Digital twins shift that work upstream — from the shop floor to the planning stage.
Eliminating Trial-and-Error Manufacturing
Traditional workflows rely on iteration:
  1. Run the program
  2. Observe the result
  3. Make adjustments
  4. Repeat
Digital twins change that.
They enable:
  • Collision detection before setup
  • Toolpath validation before cutting
  • Process optimization before production
The goal is not just to avoid mistakes.
It’s to achieve a good part on the first attempt while avoiding rework and downtime.
How Digital Twins in Manufacturing Improve Throughput
Digital twins don’t just improve programming.
They directly impact throughput.
When the process is validated in advance:
  • Setup becomes faster
  • Fewer adjustments are needed
  • Confidence increases
  • Machines spend more time cutting
  • Spindle idle time decreases
  • Maintenance and repair costs are reduced
This aligns with a core challenge in manufacturing: reducing the time between parts.
Cycle time only measures the time between pressing cycle start and the machine returning home. It’s an important metric, but often an incomplete one.
What really matters is the total time required to produce a good part — from programming to shipping.
That’s where digital twins make a difference.
They reduce total production time by anticipating issues before they happen and addressing them before they impact production.
Reducing Operator Dependency
One of the most overlooked benefits of digital twins is their impact on operator dependency.
In traditional environments, experienced machinists bridge the gap between design and reality.
They:
  • Anticipate issues
  • Adjust setups
  • Modify programs
That knowledge is valuable — but difficult to scale.
Digital twins embed that insight into the process itself.
They make outcomes:
  • More predictable
  • More repeatable
  • Less dependent on tribal knowledge and siloed experience
Connecting the Digital and Physical
The real power of digital twins lies beyond simulation.
It’s process alignment.
When the digital model accurately reflects physical reality:
  • Programs translate cleanly to the machine
  • Setup assumptions match reality
  • Performance becomes predictable
This reduces friction between engineering and production.
Where Most Shops Fall Short
Many manufacturers believe they are already using digital twins.
In reality, they are using partial simulations.
Examples include:
  • Basic toolpath verification
  • Limited collision checking
  • Simplified machine models
These tools help, but they don’t capture the full process.
And without that, the gap remains.
Digital Twins as a Process Strategy
The real value of digital twins is not the technology itself.
It’s what the technology enables.
A shift from:
  • Reactive → Predictive
  • Iterative → Validated
  • Operator-driven → Process-driven
This aligns directly with the broader transformation happening across manufacturing.
How Digital Twins Fit into Modern Manufacturing
Digital twins are one part of a larger system.
They accurately predict the outcome of the manufacturing process.
A modern CNC machine ensures that prediction holds true.
When combined:
  • Simulation reduces uncertainty
  • Machine design reduces variability
  • Control systems simplify execution
The result is a process that is:
  • Faster to deploy
  • Easier to run
  • More scalable across teams
  • Capable of producing good parts on the first run
The Real Opportunity
Most shops are still trying to optimize what comes off the machine at the machine.
But the real opportunity is to shift optimization upstream.
To arrive at the machine with confidence before the first run.
Optimizing upstream during engineering, design, and programming streamlines production and increases throughput.
Digital Twins in Manufacturing Are Becoming the Standard
Digital twins are not a future concept.
They are becoming a requirement.
Because in an environment defined by complexity and precision, guessing is no longer acceptable.
Manufacturers must accurately model and simulate their tooling, workholding, machines, and processes before raw stock ever reaches the machine table.
Final Thought
The future of manufacturing isn’t just physical.
It’s digital.
Because the more you can solve before the spindle turns on, the more efficient everything becomes after it does.
Learn more about our CNC automation solutions here.
