Before machining a part, most programmers take time to define an overall strategy. This planning stage typically includes decisions about the starting workpiece or blank, how the part will be fixtured on the machine table, and which cutting tools will be required to generate the toolpaths. In almost every application, multiple tools are needed, each with different cutting diameters, lengths of cut, and shank sizes.
The more flexibility your machine offers in terms of tool capacity and shank diameter range, the easier it becomes to optimize both machining time and part quality. That’s why spindle and tooling decisions should be made carefully during the machine configuration stage, with both current and future requirements in mind.
One key consideration is tool magazine capacity. While DATRON systems allow tool magazine expansions later, adding capacity after installation is more expensive than configuring it correctly at the factory. You should also evaluate the spindle’s collet size and the availability of adapters or alternative collets for different tool shank diameters. The shank size refers to the diameter of the tool blank that is secured in the collet.
In this blog, we’ll focus on how spindle selection affects collets, adapters, and tooling options, helping you make informed decisions when configuring your machine. As always, a DATRON representative can assist you in selecting the best tooling system for your application.
DATRON Spindle Options Overview
DATRON offers two primary spindle clamping systems:
- Direct shank clamping
- HSK (Hohl-Schaft-Kegel, or hollow shank taper) precision tool holding
Direct shank clamping is available on DATRON spindles rated at 600 watts, 1.8 kW, and 2 kW. HSK systems are offered on 3 kW, 4 kW, and 8 kW spindles.
Note: The DATRON neo series is available exclusively with a direct shank clamping spindle.
Let’s begin by looking at how direct shank spindles work.
Direct Shank Clamping Spindles
For practical purposes, there are five commonly used spindle collet sizes:
- 3 mm
- 1/8″
- 6 mm
- 1/4″
- 8 mm
The collet is fixed inside the spindle and is typically not changed during machining. Think of it like selecting a 3/8″ or 1/2″ drill chuck, you choose the size that best matches your tooling needs from the start.
If your application exclusively uses small tools with 3 mm or 1/8″ shanks, such as PCB drilling, either of these collet sizes may be sufficient. In these cases, DATRON offers a ring system that is press-fit onto the tool (or supplied pre-installed). The ring allows the tool to be securely held in the tool magazine and provides a precise stop reference when loaded into the spindle. This eliminates the need to measure tool length after each tool change.
If your application requires larger tools, up to 6 mm shank diameter, a 6 mm spindle collet is recommended. This size also aligns well with DATRON’s standard tooling range (note that DATRON does not offer 1/4″ shank tools).
Adapter Systems for 6 mm Collets
A 6 mm spindle collet provides excellent versatility through the use of adapters, which are significantly more cost-effective than moving to an HSK system. With adapters, you can use:
- 3 mm tools
- 1/8″ tools
- 6 mm direct shank tools
The adapter is made from spring steel and can be expanded using an Adapter Insertion Tool. The insertion tool uses a wedge-shaped pin to open the adapter sleeve, allowing the tool shank to slide in. Once the pin is released, the sleeve clamps securely around the tool shank.
For 6 mm shank tools, DATRON offers brass rings that are press-fit directly onto the tool, similar to those used on 1/8″ tools. These rings ensure proper seating in the tool magazine and establish a consistent tool length reference. Rings are single-use and discarded when the tool reaches the end of its life.
DATRON also offers larger cutting diameters, such as 12 mm tools with 6 mm shanks, primarily intended for surfacing operations. These tools are not designed for heavy material removal and can be used with automatic tool changes.
Overall, the direct shank system offers excellent value and flexibility for a wide range of machining applications.
8 mm Collet Configurations
Spindles configured with an 8 mm collet expand tooling options even further. The operating principle remains the same as with the 6 mm system, but with these differences:
- Adapters are used for 6 mm tools instead of rings
- 8 mm shank tools are mounted directly using 8 mm rings
Larger 8 mm tools are well suited for heavier machining operations and provide a strong middle ground before stepping up to the more expensive HSK system. However, if your application requires tools with shank diameters larger than 8 mm, HSK becomes the only option within the DATRON spindle lineup.
When to Choose an HSK Spindle System
If your applications demand high precision, micro-sized tools, and/or significant material removal, the HSK system may be the better choice. HSK tool holders are highly balanced, offer extremely low runout, and perform equally well with micro end mills, drills, and larger cutting tools.If your work is limited to small tools only, a direct shank spindle remains a viable option. But if you need a wide range of tool sizes, especially those exceeding 6 mm in diameter, HSK offers clear advantages.
HSK Tool Holding Systems Explained
DATRON uses HSK-E25 collets on its 3 kW and 4 kW spindles. These collets support a broad range of shank sizes, including:
- 3 mm, 4 mm, 5 mm, 6 mm, 8 mm, 10 mm
- 1/8″, 3/16″, 1/4″, 3/8″
Collets are available in both standard and extended-reach versions, making them ideal for tight pockets or deep wall features. Tools are inserted and removed using the Tribos® clamping system.
The HSK collet is secured inside the spindle via an internal gripper system that locks into the hollow taper at the rear of the collet. As spindle speed increases, the gripping force increases as well, ensuring a rigid, dual-contact interface between the spindle taper and face.
Advantages of the HSK Design:
- Improved Z-axis accuracy due to face contact
- Increased rigidity and resistance to pull-out under heavy cutting loads
- Greater holding force at higher spindle speeds
For safety, DATRON spindles include a system that prevents operation without a collet installed, protecting the internal gripper mechanism.
Tribos® Clamping Technology
HSK collets feature a polygon-shaped bore. When placed into the Tribos manual pump, external pressure temporarily deforms the bore into a circular shape, allowing the tool to be inserted. Once the pressure is released, the collet returns to its polygonal shape, applying uniform three-point pressure around the tool shank.
This design provides exceptional strength, balance, and rigidity, with runout as low as ±3 microns. The system is ideal for applications requiring precision, flexibility in tool sizes, and high material removal rates.
High-Power HSK Options
For even more demanding applications, DATRON offers an 8 kW spindle on the MxCube platform. This spindle uses HSK-32 collets, accommodating tool shanks up to 16 mm and 5/8″ diameters.
Configure for Performance. Plan for Growth.
When configuring your machine, it’s important to think beyond the parts you’re producing today. Consider how your production needs may evolve over the life of the machine. Spindle power, tooling range, and tool magazine capacity all play a role in long-term flexibility and return on investment.
If future requirements are uncertain, the decision often comes down to whether the added cost of a higher-capacity spindle today is justified. Regardless of the path you choose, investing in a DATRON high-speed machining system ensures strong performance, rapid ROI, and the ability to stay competitive for years to come.
Ready to configure the right spindle for your application?
Speak with a DATRON machining expert to evaluate your tooling requirements, material types, and long-term production goals. We’ll help you select the spindle system that maximizes performance and ROI from day one.
Contact DATRON today to start building your ideal machine configuration.
