Lightweight structures are fundamental to modern aerospace and defense engineering. Whether designing satellite components, UAV airframes, or aircraft interior structures, engineers constantly seek materials that reduce weight while maintaining structural strength.
One material widely used for this purpose is structural foam such as ROHACELL® foam.
Structural foam is commonly used as a core material in composite sandwich structures, providing rigidity and stability while minimizing overall weight. These structures appear in applications ranging from radomes and antenna systems to structural panels and UAV components.
However, machining structural foam cores accurately and efficiently requires the right combination of tooling strategies, workholding, and CNC platform capabilities.
The DATRON Cube series provides a particularly effective solution for machining structural foam materials used in aerospace production.
Foams such as ROHACELL® foam are engineered for high-performance composite applications.
It offers several properties that make it ideal for aerospace manufacturing:
Because of these characteristics, structural foam is commonly used as a core layer within composite sandwich panels. The foam core is machined to precise geometry before being bonded between the composite skins during layup and curing.
This requires highly accurate machining to ensure proper fit, bonding, and structural performance and typically requires specialized work holding.
Although foam is significantly softer than metals, machining the material still presents several challenges.
The cellular structure of the foam can be damaged if machining forces are too aggressive. Poor machining strategies can result in:
Traditional CNC machines optimized for heavy-metal cutting may apply excessive cutting forces or operate at spindle speeds that are not ideal for micro-tooling and lightweight materials like structural foam.
This is where high-speed machining platforms provide a significant advantage.
Machining foam effectively requires low cutting forces combined with high spindle speeds. Sharp tools and light engagement help preserve the integrity of the foam structure while maintaining smooth surfaces.
DATRON offers a range of solutions that make machining foam effortless. DATRON tooling, machining centers, and vacuum work holding are designed specifically for such applications. High-speed machining strategies that reduce tool pressure and produce clean results when working with lightweight materials. While our vacuum work holding offers flexibility that no other solution can.
By operating at high spindle speeds with optimized toolpaths, manufacturers can achieve:
These characteristics are especially important for aerospace composite cores, where surface consistency and dimensional precision directly impact the final composite assembly.
The DATRON Cube series provides an ideal platform for machining structural foam cores used in aerospace composite structures.
The machine’s high-speed spindle capabilities allow manufacturers to run smaller tools at optimal cutting speeds, producing clean cuts while minimizing stress on the foam.
Key advantages include:
High spindle speeds
High RPM capability allows tools to slice cleanly through foam materials without compressing or tearing the structure.
Stable machining platform
The rigid machine structure maintains accuracy even when machining detailed geometries such as pockets, contours, and thin features.
Integrated probing and simplified setup
Automatic probing and intuitive controls reduce setup time when machining multiple foam components or prototypes.
Efficient chip and dust extraction
Proper dust management is essential when machining foam materials, and the machine design supports effective extraction systems.
These capabilities allow aerospace manufacturers to produce complex foam cores quickly and consistently.
Reliably holding foam can prove to be the most difficult part of manufacturing structural foam assemblies. Vacuum workholding allows effortless, flexible workholding. DATRON’s unique VacuCard sacrificial layer approach provides the flexibility needed to produce the most complex parts. The sacrificial layers act as infinitely configurable gaskets that don’t need to be customized for each part or variation. Allowing multiple thorough features and thin floors that would be nearly impossible to produce any other way.
As aerospace manufacturers continue to pursue lighter, stronger, and more efficient structures, structural foam materials will remain essential to advanced composite design.
Producing these components efficiently requires machining systems that deliver both precision and process simplicity.
With high-speed spindle technology, optimized machining strategies, and simplified workholding solutions, DATRON’s Cube series enables manufacturers to machine structural foam materials at high speed, with accuracy and consistency.
The result is a manufacturing process that supports the next generation of aerospace structures, lighter, stronger, and built with modern machining technology.
Reach out today to learn how DATRON can help you reimagine your manufacturing process for aerospace and defense.
DATRON USA will be closed Friday, January 1st, 2027, in observance of New Years Day.
