Deployable CNC Machining
When Manufacturing Moves to the Front Line
There are moments when time disappears.
The system goes down. A repair is needed. A part is missing.
And the question isn’t how fast it can be shipped.
It’s: can this part even reach the frontline?
Where Production Needs to Be
At the front line, whether in disaster response, remote operations, high-pressure environments, or on the battlefield, logistics becomes the problem.
The part exists. The process exists.
But neither are where they’re needed.
For decades, manufacturing has been built around a fixed concept.
Centralized facilities. Optimized supply chains. Fixed Utilities.
But when conditions break down, distance and logistics become the point of failure.
A Different Model Emerges
What if production weren’t bound by traditional infrastructure?
What if precision manufacturing could move without compromise?
Not as a facility. Not as a fixed asset.
But as a self-contained, high-precision production unit ready for deployment anywhere.
Imagine a system that can be:
  • Transported
  • Placed
  • Powered
  • Producing high-quality parts within hours
No buildout. No complex utilities.
Just the capability you need delivered to where you need it. This is possible today with our neo machining lineup.
Power Without Complexity
At the front line, power isn’t guaranteed.
So the system adapts.
  • Runs on standard 208/240V single-phase power
    • Draws only 16 amps
    • No specialized electrical requirements
Precision doesn’t wait for infrastructure, and that capability exists today. The DATRON neo runs on single-phase power, is lightweight, and can provide real precision and repeatability.
Compact, By Design
Deployment demands efficiency.
A small footprint. Minimal space requirements.
Without sacrificing what matters:
  • Working area
  • Precision
  • Capability
  • Automation
Because the parts requirements don’t change just because the environment does.
Setup Without Friction
Time isn’t spent preparing.
It’s spent producing.
  • Modular workholding secures parts instantly
  • No complex fixturing requirements
  • Automation is built in
  • Setup is automated
  • In-process inspection is the norm
Less friction. More flow. Anywhere.
The System Guides the Work
At the front line, there isn’t time for interpretation.
The process must be clear. Structured. Guided. Perfect.
  • QR codes ensure fixtures and stock are correct
    • Integrated cameras can read QR codes from stock and fixtures to ensure compatibility with the process
  • Automated workflow validation
    • Automated system checks come with the press of the play button
  • In-process probing and verification
    • Adding probing and part verification is done quickly in minutes and is designed for production
The system doesn’t just run. It ensures the process is right every time.
Capability Without Dependency
Traditional manufacturing depends on:
  • A specific operator
  • A highly specialized expert
  • A fixed team
But what if we could change that today?
The knowledge is built into the system.
So output becomes:
  • Consistent
  • Repeatable
  • Reliable
Wherever it’s deployed.
Just-In-Time Becomes an Option Anywhere
For decades, manufacturing was optimized for speed and was built around large infrastructure.
Just-in-time assumes a perfect environment.
The next shift removes that assumption.
Parts are no longer reliant on the infrastructure they once had.
They’re produced where they’re needed.
Just-in-time can evolve to meet your needs, no matter the environment.
New Possibilities for Manufacturing
Manufacturing no longer needs to be:
  • Centralized
  • Distant
  • Reactive
It becomes:
  • Present
  • Integrated
  • Proactive
  • Responsive by design
  • Flexible
Final Thought
When production can be deployed,
it stops being something you wait for.
It becomes something you rely on.
Manufacturing, reimagined.
Precision is no longer defined by where it’s built.
It’s defined by where it shows up.
Explore What Could be next
DATRON is redefining what precision manufacturing looks like when it leaves the shop floor.
Less infrastructure. Less friction. More capability where it matters most. Explore the endless possibilities today.
DATRON next. The future of CNC. Now.
